indica
Serial flasher
Score!
YAY for me!!!!!!
SPECIFICATIONS
Brake Levers Shimano Saint
Front Brake Shimano Saint Centerlock 203 mm
Grips GT alloy Lock Down
Handlebar FSA Carbon DH. 31.8mm bar bore, 25 mm rise with 8 degrre sweep 3 degree tip
Headset FSA Orbit Z 1.5 R cold forged alloy cups for 1.5 headtube with sealed cartdride ACB bearings, with internal reducers for 1 1/8 steerer, 9mm total stack
Rear Brake Shimano Saint Centerlock 180 mm
Rear Shock Rock Shox Vivid 5.1 coil spring with ending and beginning stroke rebound adjust, compression ending and beginning strokeadjust, drop stop bottom out adjust
Crankset Chainwheel Shimano New Saint with 38 tooth ring
Front Derailleur E-Thirteen SRS Light guide with chain taco for 38 tooth ring.
Rear Derailleur Shimano New Saint short cage
Shifters Shimano New Saint 9 speed
Fork Rock Shox New Boxxer World Cup, with high speed, lo speed rebound and compression dampling, motion control, new 20 mm maxle, 36 mm stanchions, air spring adjust.
Frame Full Monocoque Carbon Fiber with forged and CNC fitments, with all new I link assembly and pivot design for 8.3 inches of rear wheel travel with Maxle rear axle QR system
Front Hub DT / Swiss FW 440 for 20 mm Axle, with centerlock
Nipples DT brass
Rear Hub DT / Swiss FW 440 for 12 mm Axle with centerlock
Rims Mavic EX-729, welded joint with Maxtal alloy material
Spokes DT 2.0 stainless
Tires Kenda Nevegal, 2.5" DH with "Stik-E" compound, butyl cap and sidewall reinforcement
Large, weighs 18.10kg sans pedal.
It is mine.!!!!!!!
YAY for me!!!!!!
SPECIFICATIONS
Nipples DT brass
It is mine.!!!!!!!
