Doesn't squeak anymore, and mine's ISO. Golden.Fuck you and your squeaky drive ring. Also fuck centrelock only.
While we are yelling at CK. Fark your stupid fragile o-ring that holds the bearing headset cap parts together and it’s a weird size you can only buy from CK.Fuck you and your squeaky drive ring. Also fuck centrelock only.
Is that when he became an electrician and hired a chauffeur?One of our boys used it for a commuter until he discovered electricity.
And fuck having to use a mallet to drive the headset cap into place with steerer spacers while trying to hold the whole front end together.While we are yelling at CK. Fark your stupid fragile o-ring that holds the bearing headset cap parts together and it’s a weird size you can only buy from CK.
....that we can agree on.Also fuck centrelock only.
I used to think the same, a 6-bolt die hard... now a centrelock convert.....that we can agree on.
Oh I'm only whinging because I've got a pile of 6 bolt rotors that would be rendered unusable. Plus I'm not sure a few manufacturers (TRP?) even make centrelock rotors.I used to think the same, a 6-bolt die hard... now a centrelock convert.
So much easier.
A cassette tool and wrench aren't the kind of things you take on the trail though. That said, how many times have you had to tighten rotor bolts on the trail?I used to think the same, a 6-bolt die hard... now a centrelock convert.
So much easier.
Its a Shimano BB for MTB, the cassette tool is only for internal CL rotor lockrings on QR bikes and roadies thru axles. Anything with a 15mm thru axle needs an external CL lockring which is the BB tool.A cassette tool and wrench aren't the kind of things you take on the trail though. That said, how many times have you had to tighten rotor bolts on the trail?
He became a computer programmer so he could afford to hire an electrician and a chauffeur.Is that when he became an electrician and hired a chauffeur?
That is tasty. I don't care how long it lasts or if it is tough to clean.
Yes you do...you need to know when to have the next one on order.That is tasty. I don't care how long it lasts or if it is tough to clean.
Ha. I posted that over in Newly Released Bikes. Cool mad science, interesting to see where it goes.Ok this is pretty cool.
A Better Derailleur? Supre Drive Splits the Traditional Derailleur in Two
The Supre Drive solves the problem of derailleurs breaking. It’s reliable like a gearbox, but it doesn’t have the drag and weight disadvantages of gearboxes. No other mountain bike drivetrain achieves this: the reliability of a gearbox combined with the efficiency and low weight of a derailleur...www.vitalmtb.com
Unfortunately CNC cranksets seem to go that way. They can make some beautiful looking goodies, but, y'know....Yes you do...you need to know when to have the next one on order.
Drop forged FTW.
That is what we are talking about. Can we get Thor's mjolnir on the heavy duty hammering action too.No way! I want mine hammered out on the anvil by a sweat Smith wearing an apron.
I want. Luckily out of stock and no 24mm spindles. They would make nice door handles
