My trail bike almost completely altered from stock:
FRAME: M5 hydroformed tubing, EVO geometry, tapered HT, PF30 BB, ISCG ’05, Command Post routing, 142mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 150mm travel (custom paint job)
REAR SHOCK: Custom Fox RP2 with AUTOSAG, ProPedal and rebound adj., SJ FSR eyelet extension, 197x51mm
FORK: Fox 36 Kashima 20mm axle 160mm
HEADSET: 1-1/8 and 1-1/2" Threadless, Campy style upper with 1-1/2" lower, cartridge bearings
STEMS: Raceface Turbine 50mm
HANDLEBAR: Easton Havoc Carbon 750mm
GRIPS: ODI Ruffian
FRONT BRAKE: Shimano Ice Tech 180mm rotor
REAR BRAKE: Shimano Ice Tech 180mm rotor
FRONT DERAILLEUR: N/A
REAR DERAILLEUR: SRAM XX1
SHIFT LEVERS: SRAM XX1
CASSETTE: XX1 10 - 42t
CHAIN: XX1
CRANKSET: Sram XO carbon
CHAINRINGS: Works Components Narrow/Wide 32t
BOTTOM BRACKET: SRAM PF30, OS press-in bearing (alloy, not plastic)
PEDALS: XT Trail
RIMS: Stans EX Flow
FRONT HUB: Hope Pro 2 Evo 32h
REAR HUB: Hope Pro 2 Evo 32h
FRONT TYRE: Specialized Butcher Control, 60 TPI, 2Bliss ready, aramid bead, dual-compound, 26x2.3" tubeless
REAR TYRE: Specialized Butcher Control, 60 TPI, 2Bliss ready, aramid bead, dual-compound, 26x2.3" tubeless
SADDLE: Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm width
SEATPOST: Rockshox Reverb 125mm drop
SEAT BINDER: 34.9mm clamp ID, 7050 hard anodized alloy collar, single bolt
TOTAL WEIGHT: 12.6 kg
