hifiandmtb
Sphincter beanie
Is the cable clamped into the derailleur arm in the correct direction?So I had another go at indexing the rear mech, to no avail. I tried spacing the chainring in and out, removing the chain guide and it still skips on the top two gears of they are under pressure. If you try and add more tension to relieve the top end skipping then it skips at the bottom end. Most of the play appears to be coming from the pop rivets in the parallelogram. It’s less than 3 months old, so I will see if mtb direct will warranty it.
