hazza6542
Here is the final spec and photos.
Spec List - Black are stock parts before rebuild
Frame - Sunday
Rear shock - FOX DHX RC4
Front froks - FOX 40 Float
Handlebars - Raceface Atlas 800
Stem - Funn Direct mount
Headset - K9 ARC -2 degrees
Grips - ODI Ruffian Green
Saddle - Deity Pinner green
Seatpost - Funn stock
Front brake - Avid Code CR
Rear brake - Avid Code CR
Cranks - Descendant
Chainguide - Csixx
Pedals - Straitline De Facto
Rear derailleur - X9
Rear shifter - X7 with green indicator
Cassette - Something new off mate
Front hub - Hope Pro II Evo Black
Rear hub - Hope Pro II Evo Black
Front rim - Spank Stiffy 40al Black
Rear rim - Spank Stiffy 40al Black
Tyres - Minion F front and rear tubeless
Total weight - 17.8 kg
Original thread begins here.
First post here in years, and with tax back coming, broken parts and injuries I thought it was time to get the old girl like new again. Plans are a complete rebuild with all new wheel set new forks and shock, brakes and most of the drive train. Hopefully by the end of it all it should make the Kessel run in less than 12 Parsecs.
Having a bit of trouble removing the two linkages, had to drill out the shock mount after I found one of the bolt heads holding it in had sheared off, so all the linkages will be getting the hardware replaced if I can source the parts, pearce cycles seem to be the only way unless anyone knows anywhere in Aus who can source em? Local bearing shop quoted me ~$60 for all the bearings.
http://www.pearcecycles.co.uk/product_list/209
First off it'll be getting a respray, I liked the paint from the 2010 demo's and a quick photoshop mock up came out nice I thought.
Will update this post with new updates
Frame - Sunday
Cranks - Descendant
Chainguide - Csixx
