That's great if they don't fall out of the packaging before they get to you....Bike24 has some crazy good deals on Schwalbe at the moment.
True dat. I've been lucky so far.That's great if they don't fall out of the packaging before they get to you....
Why bottom up? What's the benefit over the gravity bleed?Bottom up Shimano bleeders, how do you flush the system? Push it through and then discard from the cup?
Air bubbles riseWhy bottom up? What's the benefit over the gravity bleed?
Yes it will. I'm running that combo on 2 bikes. One of them 34t ring and the other 36t. You'll be rightI need to know if all this works together. the only thing I am really concerned about is the rear derailluer? Do I need the long cage? I may move to a 32t front ring eventually?
Shimano Deore XT SM-CRM81 30T Chainring for FC-M8000-1 Black/Silver
Shimano XT FC-M8000-1 11sp Crankset 170mm (no chainring)
Shimano XT CS-M8000 11-42T 11sp Cassette
Shimano XT RD-M8000 Rear Derailleur Shadow+ 11sp Medium
Shimano Dura-Ace/XTR CN-HG901-11 Sil-Tec 116L 11sp Chain with Quick Link
Thanks for that. The only problem now is I know the second I hit pay Pushys will drop a promo codeYes it will. I'm running that combo on 2 bikes. One of them 34t ring and the other 36t. You'll be right
Better than dropping a poop...Thanks for that. The only problem now is I know the second I hit pay Pushys will drop a promo code
...in your pants and then slashing your finger. In fact, much better than that.Better than dropping a poop...
Those fuckers on wiggle listed as XT....weren’t. Neither 104, or the new asymmetric 96.Running the same here, apart from getting locked up, dropping the chain and chewing out the driver it is perfect!
Actually all good.
@moorey has plenty of 32t chainrings.
