Yeah, I thought that was the issue. Just wanted to check.No, the 10spd SRAM uses the Shimano splined freehub body as far as I'm aware. They produced the XD body specifically for the 11spd release and it didn't get retrofitted.
With a decent mallet you could probably friction fit the lowest cluster.Yeah, I thought that was the issue. Just wanted to check.
Hmmmm tempting. I've got a wheel for sale that's XD but the fella wants to run a 10sp Shimano derailleur and I was trying to see if it could be done without a new driver.With a decent mallet you could probably friction fit the lowest cluster.
So you recon the eating of hippies is a good idea ?Well they aren't a disease...
@safreek perhaps some dietary changes that include foods with anti-inflammatory properties. Best ask the hippies though as it could all just witch doctor bro science...chia seeds and fish from memory are perhaps helpful, bro.
No, XD is specifically for the 10T sprocket found on SRAM 11 & 12-sp. cassettes. Any cassette which tops out at 11T (which includes all 10-sp. & less, Shimano 11-sp. and the odd SRAM 11-sp.) will not fit.Can you run a 10sp SRAM cassette on a 11sp XD free hub?
Yes. Shimano & SRAM use the same spacings across all their cassettes, so as long as your shifter & derailleur are a correct match, either brand chain & cassette will work (matching of course the number of gears in the cassette & shifter - strangely enough there are people who can't get that bit right...).And can you run a shimano 10sp derailleur/shifter on a 10sp sram cassette? I know you can interchange cassettes and chains.
A zip tie dude.Sick! I'm going to stop drinking water and get busy. Ant tips on how to not piss for a few days? I'm thinking silicon down/up the pee chute.
I don't want the tag end ripping my sack up. I am not a eunuch!A zip tie dude.
Purple zip ties are best.
70 bucks ? Streeter beater.You shouldn't buy it
Frustrating money pit that you will struggle to fit parts to.70 bucks ? Streeter beater.
Your right, was just hoping someone would confirm it as a genius idea.Frustrating money pit that you will struggle to fit parts to.
...another frustrating build. The pain of so many changed standards! But the stitching ky will be an easier build.Your right, was just hoping someone would confirm it as a genius idea.
Should probably put the 70 towards getting the stinky up and running
Chest mounted gimbals.I keep seeing stabilised GoPro chest cam videos everywhere - e.g. https://www.pinkbike.com/video/487949
What are they using to get so stable? Is it a GoPro product? Is it affordable?
Could be handy with a grinder and welder.Frustrating money pit that you will struggle to fit parts to.
