Cardy George
It'll be poetic either wayIs this an attempt at a Haiku or a coup?
I was / am lost.Wha?
You'll be next.I was / am lost.
Yes please.You'll be next.
Cheers. Not sharp per se, but only about 1-1.5mm thick. Bigger blades would be a little thicker.Great stuff beeb. Is the leading edge sharp?
you know you're getting old when playtime injuries are a serious issueRunning up and down the street with her in her little pink car my hamstring went pop.
Correct! Most mid range stuff will be like that if it's got a steering axle. Once you go articulated then tracks front and rear is no problems.Tracks and tyres on one machine?
Makes sense, I thought it was articulated.Correct! Most mid range stuff will be like that if it's got a steering axle. Once you go articulated then tracks front and rear is no problems.
But the idea is obviously less compaction with more surface area. Fairly popular around here with the 3m control traffic guys
Hard to tell from picture I guessMakes sense, I thought it was articulated.
Had to replace two hydraulic hoses today, crap they are expensive and discovered another where the crimp spins around the fitting which is not ideal. That will consume my spare hose. Need to get more made up.
I think it needs one more screw on the Northern side, West end. Steel or poly tank.Finished the water tank base:
I dare say it should be strong enough...
