crank1979
10, damn n+1 rule!I think we need a full group shot! What's the tally at now?
I'll get a group shot when I get one back from Phantom Cycles. I should be able to post up an interesting shot later tonight actually.
easy to fix by design, or just dumb luck?I had my first issue with the Pinion gearbox the other day. the chain tensioner seemed to let the chain slip a few links through the jockey wheels. It turned out the bolt that the spring fits into had been hit by one rock too many and snapped a few of the holes off. It was a fairly easy fix on the trail and when i got home i found the bolt is made with a square shoulder allowing it to be rotated if it gets damaged. 5 minutes later and it was all fixed.
Probably a bit of both. The square shoulder locates the bolt properly, but then they'd only need to drill holes in 1/4 of the flange for the tensioner to work.easy to fix by design, or just dumb luck?
I don't know the weight. I'll see about getting it weighed next time it's at the lbs.that 301 is epic. its the first i've seen with a piggyback also. what does it weigh in at? in my opinion, liteville/syntace make the best quality components/frames in the industry.
