Quick dropper post poll
born-again-biker
Is looking for a 16" bar
Looking to order dropper post next week.
Done plenty of reading from the usual suspects.
Narrowed it down to a shortlist...but need help picking the winner .
Going into a Trance 650B XL frame.
I'm just shy of 6'3" with very long inseam.
E-thirteen TRS
Pros: Good price, best serviceability, nice simple mechanical guts that I can easily maintain (this really appeals to me). Great looking lever.
Cons: Heavy! Not infinite travel. 150mm max. It's their first dropper I think...
Bike Yoke Revive
EDIT:
Pros: Carefully designed by a company that may or may not have had a casual relationship with a German.
Revive function is very clever.
Longer travels options could seal the deal
Cons: Farkin' pricey. No track record yet.
What happens when revive valve doesn't fix it anymore?
X-Fusion Manic
Pros: Great value. Good features. Cheap cartridges. X-Fusion is not new to the post market, so should be very reliable?
Cons: I don't think there's more than 150mm travel.
Brand-X
Pros: Extreme value! Good warranty. Almost no negative reviews anywhere.
Could buy 2 for the price of the BikeYoke.
Cons: 150mm max travel. Could be cheap junk?? Lever looks flimsy.
Other honourable mentions:
Crank Bros Highline.
PRO Koryak (Shimano)
So who owns what?
(Don't bother with recommendations for Reverb/Transfer/LEV. Not interested.)
I haven't used any of those, but if money isn't an issue, then I'd go with the most travel you can get, which is the Revive. They're meant to be very reliable as well and seem to have good warranty and an Aussie service centre if something goes wrong.
I'm pretty much the same size as you and have a 150mm dropper on the hardtail and the dually.
It's not as much of an issue on the hardtail, but I find I'm compromising on both ends (pedaling and getting the seat out of the way) on the dually and have to set the post somewhere in the middle which isn't ideal.
Hopefully by the time I kill this post the price of the longer travel droppers comes down a bit.
Conclusion, get the biggest drop you can afford!
Do you have a minimum travel requirement? If you choose that 150mm is too short, decisions are easier to make.
Hmm.... yeah I wondering about length...
Good to 'ear from a tall bloke (or lady)
TBH I don't know how much drop I need?
Not long ago 150mm seemed to be a lot...but as previous reply says, 150mm isn't quite enough for a tall person?
I’ve got the Crank Bros and I’ve been really impressed with it. Feels solid, high quality finish. They’re going cheap from the Germans as well.
Negatives? Well it’s a bit slower than my reverb. Long term reliability is always going to be a question but they’ve got a good warranty.
9point8 fall line
I've got a 9point8 Fall line 150mm internally routed post, have had it a bit over a year
Pros
- haven't stripped it down to service yet but it still works fine, apparently this isn't too hard to do
- no side to side play at all
- seems to work really well
- when you want to remove the post from the bike you just unscrew the post from the cable via a nifty threaded mechanism, screw it back and you're good to go
Cons
- maybe harder to get hold of in Aus?
- had some issues with the internal ?clutch mechanism where the post would not stay in the down position - to rectify this is simple, unbolt lever and push to extent of travel and hold for a couple of seconds - this has now gone away anyway
- cable is fiddly to set up initially
Would definitely get another one.
160mm travel ??
+1 for Revive.
Completely user serviceable, mtb direct has all the spares available for order. It might be a bit pricier up front, but will be cheaper in the long run if you're handy.
Now comes in 185mm travel, and the remote lever is pretty good too
Pros
Cons
Yeah I looked at these a while ago but couldn't find a local retailer....and what prices I could find seemed very high.
I guess I could get the Canadian side of my family to send one over...?
Cheers for the info.
Pitching in with a fox transfer.. easily removable and serviceable, had mine for over a year and hasn't missed a beat. Whatever constitutes a good dropper, this has it.
I'm running revives on 2 bikes and they have both been perfect. Used the air relief valve once on each when i first installed them and haven't needed it since
Fox Transfer with a Wolftooth remote is the best I've used so far. If I was in the market and I wanted an alternative to what I have now, I would try the BikeYoke.
There's an in depth review coming next week on the Bikeyoke Revive. It is easily, by far the best dropper I've used and setup. I do like Reverb's when they are tuned and running well but this thing hammers it.
I look forward to this.
I must be the only person who's Reverb works fine after returning it twice under warranty.
Bike Yoke Revive
Pros: German. accurate. Precise. Superior. arian. Schnell! Ya!
Didn't know Taiwan was part of Germany ... Or that Being born, bred and Living in Taiwan made you German ... But, I guess the sales guy is German so yeah.
That said ... It's designer is a very clever guy ... Trained me ... And the bleed valve is clever.
Didn't know he was referring to the designers of each post....
