Solid!Had a random day of feeling strong yesterday so thought I'd push the SQ a little.
160 SQ went up well and I think 170 should be there by end of September. Thats a 10kg markup on my last effort as I've been struggling with technique (which seems good now). Nothing earth shattering but it feels good to have a technique that feels solid.
Today was mean't to be light BP but I was still feeling strong so I had a play with DL and hit my goal of 190 no problem so went for 200 and got that as well. Very chuffed. Hopefully I can get 220 by the end of the year.
Solid. What do you weigh? I'd love to work out the technique for these things.Yeah I still read it. I've nothing noteworthy to add training wise, but it's great to see your progress!
EDIT: FWIW, my latest PR/Achievement is a 150x10 Deadlift - mix grip regular stance (Cant sumo to save my self). I'm working on strict bar muscle ups for reps at the moment, though it's heinously strenuous on my shoulders/elbows so I'm just doing some strengthening accessory work in the meantime. People have said that if you can do strict ring MU's, then bar should be no problem (usually said by people that can do neither ) Strict ring MU's are no problem, bar MU is a completely different movement. Much respect to those who can do them for reps.
About 82kg at the moment. So I'm not very strong - yetSolid. What do you weigh? I'd love to work out the technique for these things.
150x10 at 82 is solid!About 82kg at the moment. So I'm not very strong - yet
Technique for muscle ups?
Sweet. I'll have to give this a go this week!That's a really good video mate. Keep it simple. Work a lot on the transition (doing negatives). The only thing they didn't really talk about is hand position. Some can do strict bar MUs by starting in the false grip (wrists cocked over the bar) and do a really smooth strong MU without the quick transition. If you start with your hands in the same position as a pull up, you'll need to create that momentum to get your chest over the bar.
Strict ring MUs are easier, though require probably the same preperation (negatives, chest high ring pullups). Pull your chest to your hands, and kind push your chest through, keeping your hands in contact with your pecks the whole way.
Tricky to explain in words without a demo at the same time...
I'll never get to 200 haha. Most I've done is 139 x 3, and that was after a 6 week oly lifting cycle which basically squats and pulls 4 days a week. Now 120 feels like it's going to snap me!Sweet. I'll have to give this a go this week!
140kg high bar x 5 today. 3 rep PR. I estimate my high bar to be 175kg, and my low bar 190kg currently. I really really really want 200kg squat.
My bench is finally feeling good too! Turns out benching heavyish 3x a week did the trick.
Gainz.
139 x3! If you're pulling 150x10 I find it hard to believe your squat is so far behind. I'm assuming high bar?I'll never get to 200 haha. Most I've done is 139 x 3, and that was after a 6 week oly lifting cycle which basically squats and pulls 4 days a week. Now 120 feels like it's going to snap me!
Re bench, there's a strange correlation between getting good at some thing, and doing it a lot!
Gave you a follow on IG
Yeah, I was only benching once a week (plus heavy over head press on day 3) but clearly it just wasn't enough volume. Gonna continue with 3x a week for a while and see how I go, I've definitely noticed a difference in my body composition. I've always been small upper body with big hips and legs, hopefully I can even it out a bit more...
Also, them feels when almost adequate shoulder mobility:
I'm mad that I left my lifting shoes at home, but still happy with how these snatches looked.
Oh man I know the mobility struggle all too well. I have long arms and tight hamstrings so sumo deadlifts are super easy for me.Yeah my numbers are all over the place. Really bad mobility. So a movement lIke a DL works well because I've got a strong back, and tight hamstrings. It works against me when I squat as my ankle mobility is poor, I end up pretty unstable above the waist.
Yep high bar, well perhaps a little hybrid that works for me with my mobility.
Also I haven't squatted much recently, not at low reps anyway. Did a 105x10 3 weeks ago.... I really don't have the body mechanics to squat big numbers - check the Chinese lifting team. 85kg bw highbar squat with absolutely perfect form, 270 x 6.
Yep you'll lament leaving your lifting shoes at home when snatching!! What accessory work are you doing for snatch? Drop and hang snatches are great for speed.
Yeah it seems to be doing the trick! I think I was also underestimating my own strength. I did a week of Smolov JR which gave me the confidence to lift heavier. I've basically just cut it in half and stuck it in my regular program.Nice one mate! Volume is definitely helping aye?
100kg bench is so elusive for me, I've hovered around 95 for ages. But I don't put in the effort so I shouldnt be surprised.
Did you give MUs a go?
