That’s actually what I did after giving them a good bath. Sprayed them with alcohol then lit them up, followed by a good blast from a butane mini torch. Seemed to bed in ok so I think I saved them.Cook the pads, fuckwit.
I don’t reckon that’s enough. Cook in a saucepan on high heat. You’ll see them smoke as contamination burns off. Best done outside.That’s actually what I did after giving them a good bath. Sprayed them with alcohol then lit them up, followed by a good blast from a butane mini torch. Seemed to bed in ok so I think I saved them.
agree’d but i much prefer a frypan to a saucepan, we aren’t making sauce, i keep the heat low, if you have a kitchen fan/flue, the chimney style can be done inside easy enough, get said frypan from funnies/salvos shop, the old steel ones are best, teflon shite, Al okCook in a saucepan on high heat.
Noted, although I did keep the butane torch on them until they stopped smoking. They’re only 355 brakes and B01S pads which I’ve got more of if they are knackered.I don’t reckon that’s enough. Cook in a saucepan on high heat. You’ll see them smoke as contamination burns off. Best done outside.
Staino saucepan or frying pan. I always do outside on camping stove.agree’d but i much prefer a frypan to a saucepan, we aren’t making sauce, i keep the heat low, if you have a kitchen fan/flue, the chimney style can be done inside easy enough, get said frypan from funnies/salvos shop, the old steel ones are best, teflon shite, Al ok
you're just doing this dry? I followed the process on MTB direct website, their method is to boil up in soapy water... didn't work great though.I don’t reckon that’s enough. Cook in a saucepan on high heat. You’ll see them smoke as contamination burns off. Best done outside.
Dry. Fuck those know nothings.you're just doing this dry? I followed the process on MTB direct website, their method is to boil up in soapy water... didn't work great though.
We are like taking candy from a baby.well they know enough to take my money most of the time
boiling soapy water will destroy the resin pads, which i despise, but some round here seem to be quite fond ofyou're just doing this dry? I followed the process on MTB direct website, their method is to boil up in soapy water... didn't work great though.
Works perfectly...if you don’t actually want them done properly...i just put a drop of dish washing liquid on the pads and rub them together at pace until they come clean, it rips the oil out of the pads, rinse+repeat!
You say that like it’s an issue.you're just looking for another excuse to bring bike parts into the kitchen!
you told me to use a white wine sauce?Dry. Fuck those know nothings.
I’m not not saying not toyou told me to use a white wine sauce?
This is the actual proper way to do it.. Everyone else is just fucking around because they don't have proper toys.Noted, although I did keep the butane torch on them until they stopped smoking. They’re only 355 brakes and B01S pads which I’ve got more of if they are knackered.
